Billion Watt Load Bank Build
I had some input from a NASA tech (he got fired for being High), but it is loosely based on the info from Lee's schematic in the other thread. I got my 250watt 8 Ohm resistors and a couple DPDT Carling Illuminated resistors. When switched to the left, the illumination at the tip of the switch will indicate "Green" for left and right 8 ohm load, and to the right, the color goes to "Red" indicating left and right 4 ohm load. It will have connections to monitor both channels, power for the 12 volt fans and Power Switch. I ordered my Bigg ASS Heat Sinks. 12" wide and 18" Long for the base, and the 2 sides where the resistors will bolt to are 8" tall by 18" long and the top will hide any cobbling should I feel the need to cobble stuff......... The fan will bolt to the end cover and the front cover will have the switches and controls on the front with the air intake. The heat sinks will be here in a day or three. So far, I got $150 into it. I finally found a use for the 12 and 14ga wire Navo sent to me with a wire order a while back. I think I'll put in a heat disconnect (like the WOPL's) just in case. Maybe I'll airbrush it with Green Flames.
It should handle 500WPC (or 40 amps whichever comes first......)
Wisconsin
Fabricator
View attachment 85641 View attachment 85642
Looking good !
Definitely Airbrushed Green Flames Perry !!!!
