Yes a pair, and a klipsch sub and a center for $300. person knows retail, says pristine etc. Hope it ain't BS, but it was posted at 9:46 ish. Could be gone but things move slow in maine. Why would someone go so cheap?
Doesn't F%^$%#%^ matter CABS are worth that. Uses the same drivers as the K horns so drivers can be had cheap with a littl;e shop[ping, DUDE!!!! I would be on the road and stalking this guy!!
Never heard back from the poster. The pic you showed is the quintet, no idea why it says belle in the heading but it wouldn't be the first time I've seen incorrect info on the net.
I get suitable bass in my room. There is info down to 25hz but that's about it. At higher output 20hz is there but barely. No Issues for probably 99% of what I listen to, more likely 100%.
I listen at about 75db avg. Maybe 85 tops if that's what you mean. I'd use monitors in here but they never have enough energy down low. Or at least if they go low it's not visceral.
