BAXF'S
That's right BIG ASS TRANSFORMERS!!!!
Primary voltage----4160/2400
Secondary Volts----480/277
Outside Service Pad Type, Oil Filled-Mineral Oil
Westinghouse, Cooper Etc.....Pulled from a Coal Bed Methane Field near Gillette after plugging, 3-5 years old
30-225 KVA
Will be listed on E-Bay , starting Bid 1,000.00
11-30KVA's
1-75KVA
3--150KVA
3--225KVA
We have several 30 kva at work, but none live outside. The indoor air convection cooled units are quite a bit smaller. Ours are also 480 - 120 transformers, they run between the 480 3 phase panels and the indoor outlet panels. 3 phase 208v, or single 120v depending on what you're doing.
Normal field distribution voltage for underground stuff. Overhead is normally 12.7KV..
In back of them are some other interesting items. Skid mounted ,liquid ring gas compressors. Powered by a natural gas version of a Cummins 6BTA
Perfect for this:
