Anybody Familiar with Janszen Speakers
I know Mr. Janszen was a Harvard EE and worked at KLH for a while. I haven't found this model yet but the Vintage ones are going for good money. Needs the 10" woofs re-coned but otherwise in pretty nice shape.
Maybe 2 weeks ago, someone posted on FB with pics, looking for info on a pair of those same speakers.
I'm going to go get them for $50
Went a little while ago and picked these $50 speakers. I almost shart myself carrying them. They are heavy as hell. After Christmas, I'll take a ride over to Midwest Speakers (about 20 minutes to get there), and get these woofers fixed. Why thats going on, I can pull the Xovers and see if they need work which I'm sure they do. I'll put a few bucks into them and if they sound worthy, Then I'll do a veneer job on them and put new grill fabric on. I'm not good at it but I keep trying. Or, maybe Midwest Speaker can do them. But, in the mean time, I have 3 more preamps to rework. Looks like my Akai RTR is on the back burner AGAIN.
Those are cool speakers.
David my be offended by us but do invite him if you think he can hang.
Interesting that his son carried on the work of his father. Somewhat rare in vintage audio...
He did take over the business, well not like handed it over, my understanding is the business was rekindled by David after it was close for a while. David makes his own creations that are vastly different from what his dad made.
His are incorporating DSP and the focus has shifted to a less panel dependanr style system where they also incorporate side super tweeters and other things. Can be passive or come with amps built in and DSP, s basic model will cost several thousand and a full blown with amps will put you over $10K.
I have not heard them but I have emailed David a few times and he's always responded quickly and gave info I needed. I rounded up 28 of the old panels collected from 1959, 1967 and 1971. They were removed from various models including the toppers with 4 panels mounted at 7 (or so) degree angles (c-300 or c-30). Z-400 with 2 panels set into the front panel at 45 degree angles running in a slot with the panels touching inside the hole. I also used 8 - 2.5" x 5" panels removed from Infinitys odd speakers that were never made in mirrored sets. I think there was a error made during the start of production where they forgot to flip the motor board to make them mirrored and never bothered to change them.
I put them all around a 10 monitor audio sub and below I used a 12" woofer from a kappa 7's. They sounded fantastic but looked ugly. Sadly they are victims of a small fire and melted.
I have wire diagrams for the early models power supplies because they were not all the same. Early serial numbers were made different than later ones. The transformers typically have the wires rotted off at the solder joint inside the transformer and can be easily fixed by removing a few wraps of the tape they use to cover the windings. You'll see the paper will have green spots and grey smudges where they were soldered onto the fine winding wires.
I cleaned off 0.25" on the winding wires and tied new output and input wires long enough to run them up and back through the layers of tape as I wrapped them to make sure there's no tension on them.
The other things that go wrong are the ceramic resistors will have readings 10x the spec. Diodes tend to be really old school looking like huge and long. Replace with typical high voltage diodes, since JansZen uses a much lower voltage than others they stayed under 1000 volts , mine varied between 400 and 800 volts. 1000v diodes work fine. I bypassed the crossover on mine and went active with just 2 amps. Both the subs and woofers had excellent flat test results that went far beyond the 600 to 800Hz limit needed to pass off the signal to the panels.
One thing I found through my tests was the best way to hide the timber mismatch in transitioning was to allow an octave of overlap, I found where the panels naturally rolled off and used a simple 6db crossover setting on the woofers ending at 800Hz while the panels naturally had a very hard drop to zero after 600Hz but started at 800Hz.
The overlap was key to the smooth transition and the set up sounded amazing. I've had a difficult time finding the same sound until I found a few sets of Martin Logans for cheap. Modded Aerius with s second woofer and brought them up to a listenable level, they tested great. A set of Prodigy's unexpectedly popped up locally at s steal with one having issues. I repaired it in an afternoon with no money spent.
The Prodigy's we missing something even after repairs , the bass was weak. Bypassing the woofer crossover made them come to life. Both sets of MLs used active crossovers and 2 amps.
This is my first visit here and I'm not sure exactly how to upload pictures. I always try to present a visual of what I'm talking about so others can get a feel of what I'm saying and how it represents what I'm saying for others to gauge for future posts. You may love my ideas or work I've done or you may hate it and want to block me but at least you'll know. I don't like changing things unless I'm sure I can improve it and not spend a fortune to do it.
I will include what I felt was wrong and my mods are pretty straight forward anyone with any cabinet skills should be able to do the same. I'll never promote any products and I'm not affiliated. If I have owned something , I may give my opinion based directly on my personal experience and never anything that a friend owns or did unless it's worth the lesson or funny.
I try to do testing prior and after mods to show the difference and sometimes there's not much gain with first revisions. Not everything can be improved due to physical limitations in dimensions. I've found the shape of a cabinet can limit the Frequency allowed in the lowest frequency more than the internal volume (within limitations) even while hitting spec parameters per driver.
I have tests that suggest this, I wouldn't say it without proof. Although my tests are not conducted in ideal settings the outcome will be simple enough to show without much explanation. I'm not a professional by any means and I do this as an old retired guy who gets bored and owns just enough tools to do what I do.
After reading through a bit on the site I see there's discussion about lots of model numbers that are understood by everyone but me. I live in Peoria Az so my exposure to different things is limited to what's available locally and some research on line. I'm not a huge fan of buying expensive gear without first touching and hearing it, so that limits my availability. I learned not to listen too much to recommendations unless I get an idea who's saying it and we see things the same way.
I've been steared wrong I'm the past but my own fault.
I'll try and post my diy build before and after fire.
I'll keep my fingers crossed that my long post doesn't vanish IMG_20221120_114421.jpg
This was still in the test phase with no final plan for cabinet yet, it never made it that far before it looked like this.....
The woofers still work, those 2 blue panels were unmelted in both speakers but I have yet to test them. Only 4 didn't melt.
If you made it this far I thank you for reading and I'm including a shot of my last creation so you understand how things I make can look.
They used to use a special foam that dispersed the sound from those speakers that used only 1 panel. They made a very economical version of a 2 way that had a woofer and 1 panel with a switch or dial on back to set them for live rooms.
The foam was supposed to spread the sound to prevent beaming. The foam covers are non-existent now as they disintegrated over time. From what I gathered, that foam makes a huge difference in their sound especially when you're driving a single panel to loud levels. I came to the conclusion that running as many panels as possible and keeping their output set to just before beaming was the best way to run JansZen panels. The more you have the louder you could go, like a choir, more equals louder but less control on imaging. 2 panels won't have volume but image perfect like headphones. More than 2 and it makes no difference how many you use since the headphone imaging will dissolve from too many reflections.
It was his work with the Navy to develop a better more clear speaker for submarines that lead him to making his panels. The savings in weight along with the clarity (older speakers often were impossible to hear important announcements the first time) made them perfect. The problem came trying to market them. He ended up starting the business after not being able to get interest to make them from existing speaker makers. Dave was often at the shop and found interest in them from his visits, maybe he'll chime in and can tell the exact stories behind the processes and development ideas he saw. I've seen his posts other audio sites, he's s good guy with good ideas.
Glad to.have you around, love your perspective.
Dave will probably stop in this site at some time and correct anything I have wrong. I noticed in my files that the 4 panel toppers are I-30 and I-300 models. I have one drawing that shows how to make a transformer less power supply, I've never attempted this but it looks pretty simple and much cheaper than finding a proper transformer. I can't say for sure if you can run a dropping transformer that is a 10 to 1 meant for 120vac to 12vac in reverse but I've heard it can be done of course that's just a simple example. You'd need to be under 1kv to make sure to be in the correct voltage. If you need any power supply or wiring diagrams I have some of the harder ones to find .
The model numbers are all over the place with no rhyme or reason. The 400 series have a bunch of iterations and I'm not sure what sets them apart, if it's by years and revisions or number of drivers. I would have thought the number of panels had some affect on model numbers but that's not true.
The only model I saw with 1 panel came in a small bookshelf with a 6.5" woofer. My first electrostatic speaker was a Z-423 or Z-412 (I think) bought the pair for $50 and had to trust the seller that it worked since he met me in the parking lot of an apt building. (You'll see them with the cords cut off, not sure why , but I've seen about 50% of them without cords?) They did work but needed work to get full sound. Always check the ceramic resistors oh yeah, the selenium rectifier thing is just 2 caps tied together at the positive wires, I'm not sure how it works like that but it's simple to make a new one. Plan on replacing woofers with new modern ones to vastly improve the sound.
I found diying your own bass bins and running them as a 2-way is the best way and simple to accomplish. Just make sure the subs or woofers used test good up to 1kHz. I used monitor audio 10" subs and found they tested good as well as some 12" woofers from infinity kappas. But any decent (I always suggest any cast frame woofer) will do. I just happened to have those laying around but if I were to build another I'd look into ScanSpec woofers of any size. It depends on size of cabinet and id always mount the panels outside the cabinet or make them open to the back without much blocking their wave.
I was going to try making one where the back had a wave guide type output that could be aimed . I was going to make a separate enclosure and set it on top of the bass bin and place a loose piece that could be moved around to guide the rear waves . Once I found the best position then make a cab with that built in with the same angle that guides the rear waves.
The main part of electrostats is getting the rear waves to reflect properly off the rear walls and side walls then back to join with the front radiating waves. They should meet up one cycle behind (in phase) the front waves. So the distance from the back wall is crucial to building the sound stage and getting perfect in your head sound. You'll know instantly when everything is set up perfectly because it's like nothing else. I guess good headphones would be an example of a proper set up. Its enveloping like you're in a bubble. Distortion is nowhere to be found. Panels can be ran without a crossover and cannot be hurt unless they arc and JansZens are pretty arc proof. The large 5x5 size should be good down to 600Hz or so the smaller 2x5 are good to 700Hz or 800Hz but I would test them first.
One thing I found with JansZen panels is they all have a strange resonance that comes in after 15KHz. I can't hear anything over 14KHz and while running sweeps I would hear a loud clicking noise for a brief moment after the sound went silent as the test continued on to 20KHz.
Since my hearing couldn't hear after 14kzhz the resonance could easily be heard clearly meaning it was lower than 13KHz at some moment but may have continued after it was again higher than 14KHz . If that makes sense. So their is a flaw but I'm guessing you wouldn't notice it with music playing but it shows up in sweeps with a spike around 12KHz after it was well passed 12KHz on the sweep. It took me a while to figure out what was happening. Since it was silent but showing the sweep moving on the rta then the spike showed up near the end. I thought it was s noise that came in at the end of the test as it stopped, like it clicked off but it did it on other testing sweeps.
Just a warning, I found this happening on all the 5x5 size panels. Not perfect but they sound fantastic and are very easy to use. Don't believe anything anyone says about electrostatics unless they have owned a properly working set before.
People spread rumours out of I believe jealousy or something that I can't understand since I won't comment on things I've never owned. I don't think just hearing speakers one time is enough to know enough to comment.
Spending time with anything is a must before any conclusions can be drawn. There are times when bad is glaringly bad and after owning electrostatics you'll find that most speakers are just awful, the dome tweeter is the worst invention ever for speakers IMHO. Unless they're quality made they can't produce anything after 12kHz. Metal can but they ring and cause fatigue. Most are just plastic cone speakers with a dome shape and a cover. The best domes are silk or textile again my own opinion. Foam hardens over time so they're limited.
The best thing about domes is they can be made to replace the diaphragm (and resistance) easily but only a handful are made like that and even less still are in production. Seas and peerless are good for this, you can burn them up and replace them for $10 and get them in any ohm value you want. These are things I have learned after many years and buying many crappy speakers along the way. Sorry for rambling on
Fuck, we dig this kinda ramble...proceed at your tolerance sir...
I'll keep my fingers crossed that my long post doesn't vanish View attachment 89173
You can believe this. At least one person read your whole post and liked it. Liked! Thanks fro sharing with us and just being here for that matter!
Ramble On Brother! I think I may know where a shitload of those green JanZen speakers are. I am gonna check!
