Larry,
The K-1000 idler hub has a new tire on it. There is another new tire and clips in the baggie, so there are two new tires and clips. The K-1020 has all new belts. All it needs is the corrct size tire. The one from the K-1000 is too small. The clip from the K-1020 is also in the baggie.
I don't know if I can use the worrd Yamaha and working deck..in the same sentence. I have never sen or heard one which works..I am hoping to one day. I probably could have bought a really nice Nak with all the money I have invested in these Yamaha decks. I'd say I have spent over $200.00 in shipping alone, and probably anothe $150.00 at least, in buyine these decks. Count the money spent on belts and tires and clips....it is scary...I have over $400.00 invested and nothing that works...although I BROKE the K-1000 idler hub rocker arm or whatever it would be called, and with my super glue treatment, it is trash now...a New Transpost is all that will fix that deck..
I hope you can get them running, I just don't know if anyone can do it, it would be you though...
