Ammo Can Speakers
tivali
How do you guys have Bluetooth and AUX and what amp would you recommend for 2 speaker and 2 tweeters and a sub?
tivali
On most bluetooth boards there is a small antenna imprinted on the board; it looks like a sawtooth function and typically is located on the edge of one of the sides. You just need to scratch that antenna on either end to expose the traces, then solder the external antenna to either end. I'm pretty sure there's an Instructable here that describes how to do it -- I remember looking at it a while ago. Pretty simple really, but make sure you put some epoxy or hot glue over the solder points to protect the leads. Good luck!
