AKAI GX-635D
avionic
Fort Dodge , Iowa cornfield
Anyone ever had one of these tore apart? Got a local AK'r here that wants me to replace all of the 2SC458's in it,and theres a handful of them.Just wondering if anyone knows and easy way to access the PCB's..
stuwee
Deep in the Sonoran Desert SW
I know there's a couple folks at TH that have them, great deck!
Aren't most of the 630's related?
And why just this one transistor type? Sounds halfway anal to me.
What sort of elfin mayhem could them critters render?
speakerman1
OZONE ALLEY MARS (Visitor)
Wasted Days and Wasted Nights
I think I have a 635D. I have to look. The case is easy to get into. Mine has intermittent Reverse. It does it one one side all the time ; but the other direction it only does it some times.
Larry
I think you'd want to look at the arms.
tapepath
Baltimore, MD.
The general opinion is that the 2SC458 can become noisy over time. I've read that mentioned with Akai and Sony decks, I believe. One replacement to consider is the 2SC2240, but there may be others just as worthwhile.
Good luck with the mod...!
speakerman1
LOL Heck no. The arms are fine. If not it wouldn't do anything. The reason you use metal tape on the R2R is the sensor. As the tape goes over it it reverses the tape.
Larry
avionic
C2240's are excellent . KSC1845E's are a very good sustitute as well.
Ahhh, si! I did not know this. Thenk you.
