I recently rebuilt a 400 for my daughter. As part of the rebuild, I matched the output devices. Surprisingly, the old RCA (66546) driver transistors were well in spec (min beta of 30 at 1A 5Vce), so I kept those. The Old Delco devices were also measured for beta and leakage, and the beta tests found them lacking as there was quite a beta variation (low of 25, high of 59). I don't know that the factory matched these Delco units, but in the "old days," beta did vary a lot, so I would be amazed if they weren't matched initially.
I bought 14 MJ21196G units from ON Semi and sorted them into four groups of three based on beta.
The resulting temperatures that occurred at no load after bias adjustment:
White Oak driver:
Left Channel Output Stage (as viewed from the back of the 400):
Right Channel (as viewed from the back of the 400):
White Oak driver:
