1/4" headphone jack
62vauxhall
Southwest Kootenays BC
I posted in a different thread about getting an Apt Holman pre amp with a busted headphone jack. I have a junker tape deck with such a jack and thought about doing a transplant. Both have 3 wires connected to them but would the jack from the tape deck mute the preamp's output when a plug is inserted?
Lazarus Short
Independence, MO
​It should work if the other jack fits mechanically. The wires should naturally solder to the same place, and that should work fine.
62vauxhall
I just used jumpers to connect the jack from the tape deck to the headphone jack wires of the pre and it's a no go. When a headphone plug is inserted, signal to the preamp's main outputs should be interrupted but that did not happen.
Although I suspected as much, I just read that some 1/4" jacks have that "switch feature" and some do not. What puzzles me though is that there are 3 wires in the preamp that go the headphone jack and there a 3 on the jack I tried to use but pictures of switched jacks I've now seen have 4 terminals.
Will be visiting the local parts stores. They have those switched jacks so I'll see what they have to say.
Lazarus Short
Independence, MO
You should be able to find something to work. Now I wish I'd saved headphone jacks form dead gear. I'd have a good handful if I had.
62vauxhall
It seems my concern is unfounded. I just finished reading a Stereo Review test report on this thing and it describes a Mute button which does not affect the headphone amplifier. So that means I can use the jack I removed from the tape deck. That's a good thing since it will fit and is of better quality than those I've seen pictures of.
In my haste to get the front panel off, I did not pay close enough attention to what the switches did. I was wondering how, with a 3 wire connection and a dedicated headphone amplifier, the original headphone jack could possibly kill the preamp's main output. Good to learn that it doesn't and there's no magic involved.
