- May 1, 2013
- Australia
- Those who enter the man cave will get WOPLed
A few random Shpongle Tracks before bed, CD format
Manfred Mann's Earth Band - Nightingales & Bombers - Thorens TD 160 Super
I'm speechless on this remixed presentation.
They could have easily called it 'Un-crushed, De-Muddled'.
If you found VT completely mastered in FAIL mode back in the day like I did, you will be shocked what came out in the remix.
VT defined the worst of what the "Loudness War" was all about over ten years ago.
They completed eliminated it from this recording!
Only one word - - Wow!
Every Rush fan should give this one a serious listen..
Hi Tony,
I hope we see more albums being remixed to acceptable listening standards. I have way too many CDs that are victims of the Loudness Wars.
I recently compared an old copy of Kill City by Iggy Pop & James Williamson with the restored edition and the difference is incredible.
I can tell when I am recording from source material, consisting of vinyl and CD onto MiniDisc, that quite often the CD sources have a constrained range in output level from lowest to highest peak levels, usually within 6dBs. Easy stuff to keep in line without oversaturating onto cassette tape when I make dubs from MD onto tape. But vinyl, is most times, harder to keep levels in check with a big swing in range from lowest to highest output levels.
Tony: Good to hear the remixed version of "Vapour Trails" doing that album justice.
Taping from vinyl sources takes much more patience and skill.
You're right and it's so rewarding, nothing sounds like vinyl to tape direct recording stuff![]()
