I have a 45 year old system that I've managed to continue to enjoy with one exception. The preamp continues to drop a channel at lower volumes - in all modes - can usually bring it back by increasing the volume dramatically. I've had both the power amp (300 Series 2)) and preamp serviced professionally (preamp twice) only to have the problem recur after a few months. I'm assuming this is caused by worn or dirty contacts in one of the obsolete front panel controls. I bought a can of DeoxIT D5 with the intent to clean and lubricate these controls, but am stumped by what I'm seeing. The pots (I think that's what you call them) on the Tone and Balance controls appear to be sealed, with no small openings like I see on others that would allow the cleaner to penetrate. The stepped volume control is a cube with multiple sections bolted together - it's labeled 9D4B 50K (then ohm symbol?) X2 Japan and what looks like Alrs in script. It looks like this has been resoldered to the board, so I'm thinking it has been disassembled and cleaned previously by someone that knew what they were doing. I will appreciate any thoughts as to what you think the most likely culprit is (volume control?) and whether this is something that I could service. I know little about electronics but would be totally comfortable desoldering the volume control from the board for disassembly and cleaning if that's the appropriate step to take. One last note - the techs that have serviced these units have never been able to replicate the problem of a dropped channel. When picking up the units after service I noticed they were using very small single driver speakers on their test benches. I'm driving a pair of Nestorovic Type 3s with dual woofers, midrange and ribbon tweets - wondering if the different load or impedance the amp is seeing explains it. Many thanks.
