My Second WOPL Build This Time 700 Series 2
Southern Indiana
---6 and 7 days work week, no end in sight
I bought this PL700 II 6 years ago on Ebay. This one was wired up for 220/240 volts. Transformer wires were solid brown on the bottom post, solid blue and yellow
w/brown stiped on the second post and yellow w/blue stripe on third post. I believe that solid brown and blue wires together on bottom post, nothing wired to second post and yellow w/brown stripe and yellow w/blue stipe wires together on third post. And the 12v solid orange and yellow wires on there own post. Also line fuse was 5 amp and not 10 amp. I'm going with White Oak chassis and that is the reason for transformer not attached to the original chassis.
Is this correct wiring for 120 volts?
Southern Indiana
I got a little done on the new chassis.
I put a new coupling switch in with new capacitors and may not use them now except to cover the hole.
I see some builds the coupling switch is not used. When I did the 400, there is no coupling switch.
Just run RG316 coaxial cables from the RCA inputs to the potentiometers and then to control board.
Southern Indiana
Got a little more wiring done and to finish, I need to hit the hardware store for nylon washers for the transformer bolts.
I still have to put the control board together.
Has anyone used Kapton film tape for wrapping transformer bolts?
Southern Indiana
First test went well with Variac and DBT. Finished the control board, put in the first row of transistors. Did another test with
just the first row of transistors, all voltages check good. Installed the control board with one row of outputs.
+/- 15v readings look good.
Southern Indiana
Got all the transistors installed. All voltages are checking out good.
Bias set at .350
0v at outputs
Wired up the front panel meters including potentiometers, using RG316 cable.
Installed a Quencharc 0.1 uF 125V 150 Ohm film capacitor on the power switch.
The meters have been in the face plate for about five years, installed with the amp in its original design.
My cell phone I used for the pics probably intensified the LED's. They are bright though.
I have been noticing that in a couple of pics posted recently how bright they are. They have a version below that are not retina burners...
