Sunnbobb
I just dealt with a mouse bloom. I used the pop can over a five gallon bucket trap. Went out in the morning, and the bucket looked like a mouse swimming pool party. Ugh.
i did that once in the bodega!!!I just dealt with a mouse bloom. I used the pop can over a five gallon bucket trap. Went out in the morning, and the bucket looked like a mouse swimming pool party. Ugh.
Possibly a shorted to chassis transistor case in column 1 or 3 where column 1 is near the transformer.Here is one for the brain trust.
I picked up a PL400 with the pl14 board.
It had a blown line fuse, and the rail fuses were fine.
I replaced the blown fuse and hooked up the DB tester and the Variac, the DBT lit up very bright, and there was no voltage to the meters or the filter caps.
I checked each output transistor, and all 4 tested fine.
I then took out the rail fuses, and fired it up again. The meter lights worked fine, and the Filter caps had good voltage (80+, variac wasnt all the way up) and the DBT did not light up.
I then put the Left rail fuse in, meters lit up, filter caps charging. I then pulled that fuse and put the Right rail fuse in, and again, ights on, filter caps charging. Put both rail fuses back in, the DBt lit up and the filter caps were not charging.
So, any ideas were to check next?
Thanks for your time in this!
good time to clean up and change to sil pads or replace the sil pads if they are installed...thanks, is that a pull the transistors and test while they are out?
I never thought there would be a product worse to clean off my hands than anti-seize.good time to clean up and change to sil pads or replace the sil pads if they are installed...
i would think...
sure helps when removing spark plugs from aluminum heads...I never thought there would be a product worse to clean off my hands than anti-seize.
Well you found it then, You have a screw to chassis short going on under the right channel heatsink assembly. Time to take it off and find some broken sockets underneath it...Ok, so I removed the transistors from Row 1 and row 3. DBT did not light up. I reinstalled Row 1, DBT still did not light up. I installed the bottom transistor in row 3 and the DBT lights up. I took it out, and installed the second transistor - DBT still lights up. I can put all the transistors in row 3, and as long as I don't install the hold down screws, everything is fine. If I install a hold down screw on any transistor in row 3, the DBT lights up. I don't see any damage or crossed wires on the inside of row three. hmmmm. so close.
Are any of the transistors you removed shorted Collector to Emitter? Did you check them while they were out?And another twist/clue. If I take out all of the row 4 transistors, and install all of the row 3 resistors, the DBT doesn't light up. Then, If I reinstall one or any of the row 4 transistors, the DBT lights up.
This amp came with four 66546's as output drivers on the bottom row, and the rest of the transistors were B05's. of which 3 were bad. I have a set of 10 15025's I'd like to use, I need two more. I have removed all the B05's.. I tested the 66546's, installed them, and the DBT is behaving. Now I need to populate the rest of the transistors. Thanks for the offer!Replace the RCA B05 transistors with RCA 410 or RCA 66546 (they are the same device, just a newer number). I have them if you need them. PM me.
