Thanks, been looking at those on and off for the last year. Hoping to find something USA. Think I'm going to start researching JBL, Altec Lansing, Electrovoice.
I agree. Been checking out the local Craigslist and prices are more realistic.You're going to be paying 'collector's prices' if you're looking at those x-overs.
Get more bang for your buck, [and performance] by looking at what's 'new' out there these days.
e.g. Crossovers
One question. Does the low pass filter normally go down to 0 Hz on these? Reason I ask is I'm running a pair of subs with no crossovers built into them, in stereo "mode" with the 700 WOPL. Would like to set the low pass for the subs at 10-60 Hz or perhaps lower. Even after reading all the Ashly literature I 'm not sure.
These old Pro Audio analog active crossovers are new to me so I need to understand them before I start looking hard at, let's say, a new Behringer Super X.
The MiniDsp really looks best for my system from what I've read over the last several days. Sure would rather have a rebuilt vintage active crossover though. Going to continue to research this and learn. Thanks.You could use a stereo 3 way x-over, and just use the middle bands as a bandpass filter, but I think you'd be hardpressed to find something that would go lower than 20Hz in that setup.
Anyway, the variable x-over point is actually your low pass filter.
Yeah man, Marchand and is a big name I've come across the last couple days. Also, Nelson Pass has a nice kit on DIYAudio.If you has the time and soldering iron you could build this .. this guy has some info on crossovers.
https://sound-au.com/project125.htm
https://www.marchandelec.com/electronic-crossovers.html
