MusicJunky
 - Jul 22, 2019
I have been using a Phase Linear 700B for about 10 years (most every day) for the rear channels of my audio setup.
The front channels were powered by a pair of 400's the center was powered by my receiver.
Somehow I managed to get over-zealous and accidentally hit the power toggle on the Isobar that controlled the 700B.
I don't know did it, but I know I hit the power on and off and again on (I must have been having a bad day and If I wasn't, I sure was now !!!). . .
The 700B made a small thump and the fuses blew, 5AGX. Short story long, I could not find any 5A fuses that would fit, so I put the 700B away.
Now that I have more time and a little cash at times, I would like to recover my 700B. I have replaced the fuses, but they blow the moment you power-up.
I know the outputs did not fail as I only blew the speaker fuses. I have had outputs fail and take speaker fuses and usually at least the tweeters. The speakers were fine after replacing the fuses.
I have a schematic for the 700B, but I is very poor, and can't really read the numbers. I believe I may have blown the drivers that drive the outputs (RCA-410's)
I have some knowledge of and was originally interested in becoming an electronic technician, but had an opportunity to get into machining and making precision parts. I went with the latter, as the pay was much better and was offered an apprenticeship.
I recently discovered WOPL and figured I could maybe order the 4 driver transistors and if that does not solve the issue, I would invest in replacing the PCB with a new assembled one with the Phoenix connector. I will be able to check each output to be sure they are not shorted (I have some basic equipment). Maybe part of the circuit died as designed, to save damage to the outputs ?? Could the problem be on the circuit board?
If all goes well, I will then replace the power capacitors with the updated set from WOPL. Just need a little help/advice. I even have the purchased service manuals from Phase Linear. I just haven't found them as we recently moved. I bought them way back in the day (just in case). If I get on a lucky streak, I will upgrade the 400's power capacitors as they are from the 70's..
I would like to pass this stuff onto my sons when the time comes, and it would be nice if I left them with some equipment that still works.. This will be a hobby project as time and funds permit (I am now retired with limited income). I can't afford to have a service person do the work.
Any thoughts or helpful advice appreciated.
Thank You in advance - MusicJunky
