I got a great looking d-500 I bought off eBay last year in broken condition for a $1000. Crazy what these things cost.
So so put on bench and checked out the defective channel so I went to the one without fuses, good guess eh!
After getting low resistance on the output transistors both pos and neg output trans I exposed the back to find two marked with an X on them. It cannot be this easy can it. Well sure enough those were the blowen drivers. Reassemble with good used ones ant test good with high ohm reading across collector and emitter. I also replace the Bias transistor and both channel Zobel caps.
Powered up with DBT and could get only max 45 v with high 6 v DC offset. Tested other channel with all good there.
Next I removed the Q101 and Q107( just different label # than 400 and 500 but same)
powered up , all good, offset voltage good.
Replaced Q101 and Q107 with 2n3440 and 2n5417
repowered again original high dc current. Tested with AP and spectrum analizer and scope
see photos. For a big mess 12 k output.
Diconnected protection with no change.
Now which to change Q102 mps A93, Q106 40412( the big heatsink one) with 2n3439 or the IC.
Anyone got ideas.?? Problem on control board for sure.
