- Jan 14, 2011
- Gillette, Wyo.
But still only 16 output devices....
Does he remember building it??
Yep only (16) devices. Even the very early 700's built in 1971 with the PL0171 pc board only had (16) transistors. (12) outputs and (4) drivers. These early amps often times had no serial numbers on them.
The bridge amp had from what I can tell so far.... no drivers mounted to the heatsinks.
I am certainly no expert on this one yet. I hope to spend some more time with Bob and get to know this amp better.
It does not have the original output transistors which I had asked Bob about several years ago. He stated that they were Motorola transistors. I have installed GM/Delco DTS411's for the moment or until Bob gets a chance to review some of his old Motorola data sheets and tell me what the originals were.
Dig you get to bring up the "coffee can" amp??
I would hazard a guess it is not a paragon of low noise....
Here is a photo I took of Bob Carver this afternoon with my Phase Linear 700 (made in 1970) (a.k.a. Kelly DeYong 700 since Kelly DeYong ended up with some of them in Vancouver, BC). This was the second generation of the Phase Linear 700 amplifier. It came out after the "bridge amp" and before the PL0171 series pc board in 1971. Exact production numbers of this amp are unknown. This is the only known survivor at the moment. What is also unique about this amplifier are trimpots in the protection circuit. I also have a schematic.
I asked Bob how to adjust the trim-pots in the protection circuit. Apparently they were adjusted for "common-mode conduction" at 20KHz and at rated output.
There are some very interesting articles on the internet and in some of the Phoenix forums about "common-mode conduction",..... quasi-complimentary output amplifiers,...... using slower output transistors, etc.
I saw firsthand an example of common-mode conduction many years ago on a 400 series 1 amplifier. The older slower devices would blow fuses when the amplifier was being driven at 8KHz or higher into a 4 ohm load. This did not happen when I was using MJ15024's as output devices. However one must be made aware of how to deal with any oscillations when using faster devices (i.e. MJ15024's, MJ21194's, MJ21196's) in circuits that were originally made for slower output devices (i.e. PL909, XPL909, FPL909). One must possess the proper test equipment and knowledge on how to deal with these oscillations when and if they occur.
As a side note: I have also attached a copy of US patent number 3,727,148 "Amplifier With Protective Energy Limiter Circuit Components". It does not go into "common-mode conduction". However it does discuss the protection circuit Bob designed.
Gepetto;162523 Nirvana is semiconductor devices in your amp that do not come into play and impart any significant phase lag before 890KHz[/QUOTE said:
So it's the circuit not the devices that usher in phase lag/lead??
I spoke to him about it a number of years ago. There are a variety of different stories I have heard from people that were at the McIntosh clinics or knew Bob at the time. Some people say it exists some people say it doesn't. Some people say it refers to an open chassis. Others say it was a coffee can full of blown output transistors that were accumulated while Bob was designing the original 700. Some say it was kicking around for a while as a door stop. I have seen photos of a coffee can amp in a brand new Folgers coffee can. Needless to say, I will check into the "coffee can" story more for you.
