I'll touch these up and post pics within the next day or two. Got some stuff to do. Thanks for the advice. Any harm in running it like this for the next day or so?
No harm at all, just heading off your next repair.
Are you clear on what the diodes are D2??
That are stood off the board...yes sir. Higher voltage caps work well...but there is some debate as to how f AR above you can go. In my world anything from 0 volts to 100 is interchangeable if theyfit...
And those are all 105 degree caps so .....
I think so....should be some Panasonic too. Panasonic builds some good csps.
How's the WOPL treating you?
Yeah....I like mine too.....
Is your main one still the Pig 400?
Transformer gets that hot that I can only hold my hand on it for a couple of seconds...is this ok? Nothing burning up though.
