Transformer buzz- should I worry about it?
MarkWComer
Gaston, SC
My transformer buzzes. Not objectionably, but I do hear a 60Hz "heartbeat" coming from the back. It just sounds like a clothes iron or an electric train transformer that's been energized.
Anyone else? It's a PL400/II.
Is it an imminent sign of death?
Try tightening down the bolts that hold the tranny in place? If it was a Carver, I would know what you mean with the mag coil. Not familiar with the PL400 II so I am not sure
I've had this happen on every Harman Kardon CD-5 cassette deck I've ever owned.
Is it delamination?
MarkWComer
Gaston, SC
Is it delamination?
Ferrite stacks don't show any separation. The bolts holding it on do show some rust, though. As I said, it isn't objectionable, it's not even all that loud, it just bothers me that it's there.
Get a 7/16 wrench and a ratchet and a 7/16 socket and put the tight on those tyranny bolts and stop just before they strip. Grade 3 bolts so.......
gadget73
The only time I had a really noisy transformer in something that just would not shut up by messing with the bolts, I loosened the screws on it and brushed a bit of thinned varnish on the lam stacks. I let that run in for a couple minutes and then tightened it up. It was quiet after that. I think the varnish that originally was supposed to be keeping the lam stacks tight had just cracked up over the years and they were buzzing against one another.
When transformers go bad, they get hot and start stinking and dripping goo. If yours isn't doing anything unusual, I wouldn't worry about it.
Pure_Brew
New England
Coffee filters
I've had these amplifiers in my possession and every single one of them had some transformer hum:
Nakamichi PA-7
Adcom GFA-555
Fosgate Audionics 2100
PS Audio 200c (had this transformer sent out for a redip in a vacuum - no change)
Pioneer SX-1280 (reciever-large transformer)
Phase Linear 700B ( Lee's lender )
Jolida 502BRC
& other amps I can't even remember.
It's pretty normal imho. However, some dimmers on lights can cause this or worsen the sound of it. There are filters that reduce transformer hum, but the ones I've seen only work on toroidal types.
Take Care,
Joe
gadget73
yeah fair point, dirty AC lines make it worse. DC on the power line will also cause noisy transformers.
