- Nov 3, 2016
- Brooklyn NY
- Are you satisfied with the life you're living
Read the warning first, and then sit with your hand on the volume control. The gut-shaking thuds may well cause woofer bottoming or amplifier overload.
If your power amp(WPOL) is capable of ripping your woofers apart, the cannonshots will give it the opportunity to do so. Telarc's warning in the booklet (and on the album cover) should be heeded.
