Hello Reel tape deck persons,
As of late I have been getting in a lot of X2000R models for repair. This leads me to having to calibrate them and try to make them as good as new operational wise. The unit I am now working on has about 200 to 300 hours on the heads which are the CA orange heads. The Left channel has a lot of trouble being equal with the Right Channel at 10 KHz. When I get it equal using the bias control my analyzer says 7% distortion which is not acceptable to me. So the next idea is to optimize the head contact or at least make sure it is a best as possible as assembly lines do not leave a lot of time for adjustment. I can see from visual inspection that there is an hour glass wear pattern developing that indicates a higher tape contact with the bottom of the head that at the top. Looking at the head diagram in the book it is clear that there is NO tilt adjustment in the head mounting system and that the tangency adjustment is almost a waste of time. I have to make it known that those contemplating the purchase of a reel to reel deck on E bay or anywhere else that I can see that the X1000R design is a far better product in the way it is implemented than the X2000R design. I can't believe they have come up with a head mounting system like this as it seems to be adverse to that of the design of a good machine on the X2000R. I can see some headaches ahead for this model. If I were you I would buy the X1000R or X1000 deck as the X2000 models continue to prove to me- a past Teac Technician that they are not even as good as the X1000 models that were their pre-runner. If any of you X2000R gurus have any ideas to help me along I will be happy to review them.
It is almost like you should buy an X1000 head base plate and mount all the X2000R heads on it so that the composite machine will work to acceptance.
