Well, we are not switching an automotive AC clutch coil. You are talking about large inductive loads across the relay switch contacts. I am not aware of any inductive loads inside the Phase Linear 3000 Series II preamplifier relay circuits.
When a relay is used to control an inductive device (relay coil, solenoid, transformer, small motor, etc.), the energy stored in the inductance in the device will subject the relay contacts to a high voltage when the relay contacts open. When the contacts open, the contact gap is initially small. Arcing across this contact gap can occur immediately after the contacts open. This can happen in resistive as well as inductive loads, but inductive loads generate a higher voltage and this causes increased arcing. Increased arcing decreases contact life. Direct current (DC) inductive circuits typically use a diode to prevent the high voltage. The diode in the circuit is called a suppression diode, flyback diode, freewheeling diode, or catch diode. However, a diode cannot be used in an alternating current (AC) or audio circuit. AC arc suppression requires the use of a metal-oxide varistor (MOV), a bidirectional transient voltage suppressor (TVS) diode, or an RC suppression network. An RC suppression network is also called a snubber. The various arc suppression methods have various advantages and disadvantages. Using no suppression is also an option if life is adequate without it.
(most of this was from a Littlefuse application note)
