- May 14, 2014
- Southwest Kootenays BC
I got hold of an old, long idle amp and EQ recently. The EQ has 20 slide controls, the amp has 3 and most were noisy. Instead of using DeOxit, I used MG Chemicals Contact Cleaner with lubricant. It did make the controls noise free but the lubrication component was ineffective. In fact they were harder to move afterwards.
The reason for not using DeOxit was that some time ago I used it on a different old EQ with 40 slides and those slides also got very stiff, some to near immovability. I've encountered a couple of retired techs who've used MG cleaner exclusively for years and I have no complaint about the product for that purpose but the "lubricant" aspect seems a bit of a misnomer.
I know there's such a thing as fader lube and I believe some is marketed under the Deoxit brand. There are some instrument and PA dealers nearby who I called to ask if they carried it. Oddly, neither did. In fact one parts/service person said he used nothing but straight DeOxit and had never experienced controls being hard to move after applying it.
I have a silicone spray Gunk automotive product and am tempted to use it but hesitant to try. The label states it has a high dielectric component and I am unclear as to if that means it impedes or enhances conductivity.
I am sure I can find a can of fader lube for sale somewhere but can't really afford the $25 per can it's supposed to cost.
Does anyone have a cheap and cheerful remedy for making slide controls slide more easily?
