- Oct 15, 2014
- ---not quite right
Anyone know about this? I have a UN58RU7100 Samsung that has no audio out other than optical and HDMI ARC. I can get a DAC easy enough but according to the interwebs the optical output only works when the source is 5.1 and the HDMI ARC seems to have issues playing Netflix (which I don’t use) and YouTube (which I would like to be able to use). Seems the issue is the apps default to Dolby digital rather than PCM with no option to change setting so no sound to the DAC...
Has anyone come across this? Worst case Ontario I have an older Samsung I’m pretty sure has analog output 3.5mm I think... might put it for use with the old gear.
