- May 14, 2014
- Southwest Kootenays BC
This is not PL related but I've been trying to figure out why a 1 watt, 56 ohm wire wound resistor is heating up. It would be too hot to touch if I kept power applied.
I pulled it from the circuit and it does measure about 56 ohms. There is the correct 24V going in to one end and around 13 volts at the other but it's supposed to be 20.5.
As I bring the variac up, the resistor heats up fairly quickly once it starts receiving 24 volts. Since it's dropping more voltage than it should, it seems logical that would account for the high temperature.
But I don't get why the resistance checks out. That being so, it cannot be defective, can it?
Any thoughts?
Any thoughts?
