- May 14, 2014
- Southwest Kootenays BC
I am hoping someone can provide insight into this. I have replaced lamp bulbs before and it was a fairly cut and dried process.
Yesterday I visited someone who recently purchased a record store. Because I got some of her 2nd hand vintage turntables to work, she handed me a Pioneer SA700 II. It was the amp she got with the store that was used to play music in the shop. She said it would make spurious noises from time to time so swapped it out with something else. I think I discovered what that problem could be - 2SA798 twin transistors with black legs.
But first, I thought I'd fix the power on indicator lamp. It was apparently working when the amp was pulled from duty but it no longer does.
I removed the lamp bulb which is identified on the schematic as PL1 - 8 volt 50ma. There is no continuity so I declared the bulb dead. Then I measured the voltage present at the two points the bulb was wired to, pin 52 and ground. I measured 42.6 volts AC. My thought was no wonder the bulb was dead.
As an experiment. I temporarily wired a 12 volt 30ma bulb in place. It did not illuminate. I then tried an 8 volt 50ma bulb but it too did not light up. Am I wrong to assume that if the required or even greater voltage is present, that a bulb will at least glow?
Apart from that, I'd also like to learn what the segmented line indicates that passes through pin 52, pin 55, pin 54, etc, etc. I have not found an online explanation.
