..so I joined to beg questions and directions from fellow PL owners.
So, I was given amp two years ago, condition unknown with no meter lights. I found a very hard to read service manual PDF, read through the troubleshooting to see if safe to use variac with no output load. Fuses appeared original and tested good, Outputs also appear original with blue, delco?, ink. Both power supply caps read 6200 uf using Fluke meter. However, DC was only reading 77 +/- volts respectively.
Watching ac clamp current I brought up to full voltage without any drama. DC offset less than 32 mv on both channels. I let it idle for an hour with no signs of heating. I did not measure offset as work called and stuff packed up. Returning home, I used amp to drive old fused AR stereo sub..for two years! Anyway, yesterday, I now get a quick meter spike with pop in both channels during power up. This is intermittent but also noticed faint popping noise out of right channel, also intermittent.
Not being smart I'm guessing driver board so would love to use the PL14 20 Control Board Kit for upgrade. Trying to keep cost down so thought I would get opinions and what else I need to check. I'm learning this stuff as I go so don't hold back. I have a scope with leads in the mail.
Thanks for any advice, Mike
