Hello.
Ever since I acquired a 400 amp a few months ago I have been reading through threads here on WO upgrades etc, great stuff and the amp continues to get better and better. Great stuff here, thanks to all for taking the time to post your knowledge!
I now have a PL-2000 which works well, but has a right channel that sounds thin (lacks mid to low bass) in the phono stage. Sounds great on aux input. It came to me this way with some excess noise on the left channel that I solved by rebuilding the phono stage (caps and MF resistors) - along the way of course, all solder connections are now new. Cleaned all pots, rca conncections as well. (I've swapped input and output cables to confirm that the issue is in the pre-amp, specific to the right channel)
I installed sockets for the phono and ambiance circuits so I can swap around ICs (I have three 4739 - two NOS and one that came with the unit) IC changes do not affect the right channel's lack of low end.
The right channel RCA input jack was beat up (cracked, etc) so I replaced with one of the tape input jacks (looking for a replacement if anyone has a couple laying around?) Thought this would solve the issue - no luck.
Power coming to IC pins are +16 and -16, so that seems on target.
I have the schematic and service manual and don't really see any voltages to check related to the phono stage.
Any thoughts on next steps to track down this issue would be most appreciated.
