- Mar 6, 2022
in addition to the phase linears...i have a 78 model sx1080...at first it started cutting out...going silent...i blamed it on my internet...then i discovered that was not the problem...it would shut down the come back on...over time the cutting out came more often and the coming back on took more and more time...i did accidently short out something i should not have trying to read my dvm in a tight place...make a long story short it is back up and running...after changing a few parts...
only one problem left to conquer...
when the stereo/mono switch is in the stereo position...no right channel...only left wattmeter registers...balance will silence left side when rotated to right side...
when the stereo/mono switch is in the mono position....both channels make sounds...both wattmeters register...balance performs as normal...
i would appreciate any insight on this...
btw...i did successfully change out all output transistors with 2sb755s and 2sd845s...was able to set the center voltage and idle current correctly...
hoping i am at the end...
thanks in advance
thanks in advance
