- Nov 3, 2016
- Brooklyn NY
- Are you satisfied with the life you're living
Thinking of getting this.. My friend saw it in local pawn shop in Florida.
75 Watts per channel amp, but quite heavy due to dual transformers (one per channel). .Some specs.Nominal Output Power 2 x 75 watts ( 8 ohms)Music Power 2 x 120 watts ( 4 ohms)Performance range 5 Hz -35 kHzFrequency range 5 Hz -60 kHz (-3 dB)THD at Rated Output Power (1kHz ) 0.05 %Intermodulation distortion (150 Hz / 7 kHz ) < 0.09% to at rated powerNoise ratio (at 50 mW / channel ) Phono > 60 dB , Volume 1/2 > 60 dB , AUX > 60 dBDamping Factor 30Crosstalk attenuation 45 dB (at 1 kHz)Inputs:
