- May 14, 2014
- Southwest Kootenays BC
This Toshiba turntable I got a couple of weeks ago had a very dim strobe lamp and once removed, the blackened/silvered inside surface explained why. It is also friggin' huge compared to some NE2 neon bulbs I have. I've played around with an NE2 trying different resistors to see what difference in brightness might be achieved. The resistor used for the original bulb is 15K and what is recommended for an NE2 is 100K. I've tried about 6 different values between those two and there is a perceptible difference in brightness as the resistance get lower. Not substantial but noticeable. To achieve a brightness closer to what the original bulb produced when in good condition, the thought occurred of using two NE2's in parallel. There is enough room inside where the original bulb was housed. The voltage feed is AC house current. If I were to parallel two NE2's and use a single 35K to 60K resistor, would this work?
