Mini SugarCubes...
BlazeES
Sweet Vinyl gone 'mini' and finally added MM/MC phono inputs... which should have been the obvious choice the first time around.
BlazeES
Line-In Maximum Level: +20 dBu (7.7 Vrms)
Line-Out Level: Line-In level
THD+N: 0.0025% (A-weighted)
Frequency Response: 15Hz to 60kHz
DC in: 5 volts, center-pin positive
Average Power Dissipation: 9 watts
Gain:
MM: 36/40/46 dB
MC: 54/60/66 dB
MM Loading: 180 or 360 pF
Signal/Noise Ratio: >80 dB A-weighted
Impedance: MM: 47k Ohms; MC: 20 to 5k Ohms
Frequency Response: 15 Hz to 60 kHz
RIAA/IEC: ±0.5 dB, 20Hz to 20 kHz
Rumble Filter: -3 dB at 12 Hz
Connections:
2x Phono-In RCA (Left–Right 2x Line-In Level RCA (Left–Right)
2x Line-Out Level RCA (Left–Right)
4x USB type ‘A’ connector
1x Ethernet: Gigabit
Dimensions (WHD): 8" x 8" x 3.5"
Weight: 6 lbs.
Thanks for the heads-up, Tony. I haven't checked the Sweet Vinyl web site in awhile. Glad to see they are expanding their line-up. I've been using my SC-1 without issue since new. Best modern component in my system.
BlazeES
Looks like a USB thumb drive sitting on top Nando. I assume it came with the 'kit'. What was on that ?
That is the WiFi USB stick to connect to your network, Tony. I haven't checked out the list prices on the Sweet Vinyl products, but I got one of the early production models of SC-1 and got a discount through Innovative Audio because of the Record Store Day Special, at the time.
