Little freshening up project 700 Bravo
Kma4444
So I gifted myself some things and Santa Eric delivered.
These were from my dad's estate and I have been delaying and delaying but I'm finally ready to do some things in earnest. Should be interesting, I'm pretty technical but not an electronics expert by any stretch. But for sure the one smart thing I've done in this project is deal with Eric. He did a awesome and quick job of getting the boards done to me the only thing I'm waiting on now is a package from White Oak. Then the comedy of watching me put it all together starts. I'll be sure to post a lot of pictures and let you guys know all the problems that I cause at Eric has to bail me out of.
Also a picture of my little room they are going to live in.
Disassembly day for contestant #1. I picked this one for no particular reason. Lots of previous modifications and some ugliness. Anyone sees anything I should need to address please say so.
Not sure how much of this is still Val's work. I was a bit disappointed in the wrong size washers on the transformer mounts, not to mention the full thread bolts
Now to attach some wires to the new boards. Expecting a bunch of other goodies from WO soon. Nice to finally make progress. I have drug my feet long enough!
If you kind folks, who know things, could take a look at these and critique, it would be most helpful. Don't worry, I don't have feelings anymore so let me have it!
Remove the Orange wire at pin 5 from each backplane board.
You will be running separate wires from the control board pin 5 to the bulk cap bus bar assembly.
Also, continue heating wire to board solder joints until you see solder flow on the other side of the PCB.
Copy that, thank you very much sir. Was wondering about the time to allow the solder to flow. Didn't want to cook the board. I will go back and get it as you say.
I find that if my iron temp is suitable, I see full flow in under a second or so. Were I keeping heat on for 3 seconds, myself, I would worry about roasting components, the board and knocking foils loose (and consider turning up, or getting a hjgher wattage iron).The faster a clean joint is made, the less heat conducts into boards, components, insulation burnback on wires, etc. Proper flow is something you see, not time. (Granted, large parts, joints to chassis, etc. can take longer . . . but I thought we were talking about parts on a PCB, so responded accordingly.)
Yeah, not anytime is set on stone. If it conducts like it should , with just a dab of fresh solder, and then it melts incoming solder, then in a short jiffy, IF IT LOOKS RIGHT, I'm getting off that joint. Tim I understand the counterintuitive move of turning up the temp, but less time in contact is more productive than less temp. Learned that on those PL0171 boards and anything in a 3300, 2000, 3500...gotta MOVE IT on those boards....
Yeah, that and a gentle touch is my reason that I never seem to have any issues reworking old boards.
Hot, fast, and off for the win! (And good equipment helps as well . . . )
Tim consider that in a production environment the circuit boards are run through a solder bath with molten solder flowing under the boards like water. Likely 600-700 degrees and the solder bath could be 24-36 inches long with a conveyor speed of 4-6 inches per second.
In other words proper flow is measured in time, not looks. There were no cold solder joints with this practice. Nor were there any "roasted" components.
Check the specifications of any of the components we use, they list the solder heat exposure time. They do not describe how it should look when you are finished soldering.
This was my experience running the solder bath and the de-fluxing tank at a few electronics firms over the years. However, everyone has their own technique and preferences.
I've worked with wave lines . . . . the full machine may be that long, but the actual solder wave is no more than 1/4", so contact time is very minimal. The rest was modest preheat/post cool, and a wash.
The machine I used had a primary preheat of 350F and a secondary preheat of 480F. Total preheat tunnel length was 4.2 meters. The solder bath soldering temperature standard typically falls in the range of 240°C (464°F) to 260°C (500°F) with a max of 280C (536°F). The wave was a bit more than 1/4", total time in the bath was 2-4 Seconds.
Yeah . . . the ones I worked with were on the assembly line at Motorola, and had a fat, far, shorter wave (It was in 1984 or so, so no pics). 460 to 500 is relatively cool compared to iron temps, so likely makes the diff.
Oh, and note also on that wave that it slopes down to the right a fair distance. I doubt a card would be in contact across that entire flow area . . .
(I also seem to recall that the really heat sensitive parts went on after the wave . . . everything was automated pick and place as well, hut it has been so long that some details have faded . . . not sure if there was any hand work post wave on that line.)
