Got it Lee.
If you mean C102, 103, 104 and C202, 203, 204 then absolutely. You will have to screen caps to get within the 2% tolerance to maintain the RIAA curve properly. While you are in there, you should replace R101, 102, 103 and 104 with 1% MF resistors to improve the channel to channel balance and reduce the noise floor.
