The JBL EON 1500 is a 15-inch, 2-way passive PA speaker designed for versatility, portability, and durability, catering to both live sound reinforcement and stage monitoring applications.zzounds.com
Key Specifications
• Speaker Configuration: 15" woofer with a liquid-cooled titanium-diaphragm compression driver
• Frequency Response: 55 Hz – 16 kHz
• Sensitivity: 98 dB (1W @ 1m)
• Coverage Pattern: 60° x 90° (horizontal x vertical)
• Power Handling:
o Continuous: 225 watts
o Peak: 900 watts
• Maximum SPL: 129 dB
• Nominal Impedance: 8 ohms
• Connectors: Parallel 1/4" and NL4 input connectors
• Enclosure Material: Rugged copolymer housing
• Mounting Options: 35mm pole mount socket; dual-angle design for use as a floor monitor
• Dimensions (H x W x D): 27" x 17" x 17.5" (686 x 430 x 444 mm)
• Weight: 38 lbs (17.24
Key Specifications
• Power Handling:
o Peak: 900 watts
