Several years ago I bought a computer fan controller with thermocouples to mount on heatsinks and a variable output to drive 12 VDC fan motors. As heatsink temperature rises, the fan picks up speed. The controller fits in a 5.25" floppy drive bay. I bought a stand alone case and mounted the controller in the case. It worked but I didn't have the time or means to put it all together. Mounting the thermocouples to a heatsink was a problem.
Today you can buy 2 rolls of double sided heatsink tape on Amazon for $10. The contoller can monitor up to 5 devices and independently control 5 fans. I mounted the thermocouples close to the outputs on 700B in the pics. Mounting to the transistor case is asking for disaster as they run at +/- 100VDC and Im sure the thermocouples aren't rated for that. 4" fans will fit snugly between the heatsinks on 400"s. On the larger 700 they are standing alone with no support.
I've did a considerable amount of destructive testing on 400's when I developed the relays boards. With only one output in a 400 it will blow the transistor in a minute or so when running bout 70 watts which is worst case condition. I consistently recorded case temperatures above 140 degrees C at time of failure.
Now all I need is a night to rock out and see how it works. The Marantz in the pictures is for show only. I couldn't see keping it on a shelf in the basement..
