Howdy,
I think I have blown some speakers and am not sure on if its possible to reapir. Are there any places that work on cross overs or any one who works on any speakers kinda guy?
1 Bad Energy C-5 Connoissiur
1 Bad JBL L80t
And I need some re-foams on Klipsch Heresy K-22 12" woofer.
Thank You.
Cory.
I'm sure this place can set you up with those repairs.
Click on the linkhttp://www.madisoundspeakerstore.com
I have no affiliation with said web site, as I do most of the repairs myself to my own equipment.
There also might be some available master technicians here with there advice on your temporary dilemma.
Crossover repair is easy if you can solder and follow a schematic. Refoaming is not rocket science either, but can be a daunting task in itself. Re-coneing and replaceing a voice coil is another matter in itself. I would let the pros do that. Especially if its unobtanium speaker. If all else fails these company's will advise you on what they have that can match what was once in the cabinet.
Maybe a search on Google for the company to find out if in fact they have a replacement driver in stock.
I for the most part own Polk Audio speakers, and they still manufacture replacement drivers to this day.
Check out that auction site too you never can tell if what your looking for might be there as well.
