Garnet Gnome
AngrySailor
---not quite right
#30
Was looking at those transformers today, not sure 350/0/350 is correct? I’m getting ~290vac from the good winding no load/diodes lifted. Won’t 350/350 be too spicy? The filament winding is 6.3vac and good. The schematic specifies 515vdc after the diodes...
BlueCrab
#31
So the schematic that was posted shows 515vdc at point A. If this is correct, then the transformer would be 515*0.707 = 364 vac (assuming no load). I think the 350/0/350 would be just fine as tubes will work over a wide spread. However that first cap is shown with a working voltage of just 350vdc - way too low if indeed the voltage after the diodes was/is 515vdc. That cap's working voltage is too low if the transformer puts out 290vac, which would give about 410vdc across that cap.
AngrySailor
---not quite right
#32
290 no load, my field of knowledge is more based toward mechanical engineering, I knew there must be math to fix this
