Here is a fine pair.
The D-500 is a late modle which has nbeen well checked over. It has had newer power caps installed with a new 50 amp bridge rectifier. The control board has been upgraded to the lf351 opamps with 7.5k dropping resistors. As well the output pairs are new with other new resistors as required to get in speck. Full output at 520 watts into 8 ohms Dc offset is 4mv left and .45 mv on right. Bias set to .350 volt on high rail voltage
The Carver C-4000 has been upgraded to new electronic caps. Bipolar through the signal path. It has upgraded opa2134’s in the main amplifier section.
So here it is folks, and Steven, only $3,000 USD plus shipping for the pair
Very clean original pieces.
PM me if interested
PM me if interested
