Kinda wished they had deleted the entire thread though as I somehow keep getting my name attached to threads I have nothing to do with. I can only guess by some odd and random stroke of moderation
[quote="Rex Everything":2o7es1tu]Kinda wished they had deleted the entire thread though as I somehow keep getting my name attached to threads I have nothing to do with. I can only guess by some odd and random stroke of moderation
On a side note didn't my (and stus) hot little Avi friend used to be bigger? I think I posted a smaller one after I took down the very cool Cthulhu sprite[/quote:2o7es1tu]
Yep it probably was, if you look at change avatar under your profile, you'll see sizes for height and width in mm's, you might have changed it to make the sprite fit. look and see.
Could be you never know with these Mods. Especially me. If you suspect something contact me. If I don't have an answer I will find one. But in this case I have answers.
Ask and you shall receive. Lee has now started the thread. The stockholders didn't want to be advertising for the competition in a thread title so I renamed it as best I could since I am not sure what your first post was hinting at I made my best guess. Even us unpredictable mods f-up once in awhile and some times more frequently.
[quote="Rex Everything":3pcjxhcu]Kinda wished they had deleted the entire thread though as I somehow keep getting my name attached to threads I have nothing to do with. I can only guess by some odd and random stroke of moderation
Ask and you shall receive. Lee has now started the thread. The stockholders didn't want to be advertising for the competition in a thread title so I renamed it as best I could since I am not sure what your first post was hinting at I made my best guess. Even us unpredictable mods f-up once in awhile and some times more frequently. [/quote:3pcjxhcu]
It still says Rex did, just what are you doing back there?
