Happy new year to you all, and I really appreciate the warm welcome. Nando invited me here from another forum, and I'm glad he did. I have not seen another forum quite like this it is very unique, and seems a lot more laid-back.
To the topic at hand;
I am not a technician, I do not fix my own gear except for simple projects over the years, and I consider my strong suit to be in set up an implementation of my gear. I'm basically a objectivist and I want to see the data, I want to see the measurements. But I do hear differences in my gear, especially my turn tables and cassette decks, there is a definite audible difference that can't be denied.
sooo... my one deck does not have any capacitors in the output section from what I'm told, and it is a fairly high end deck, but not with some consider the cats meow so to speak.
You know all the tweaks that we see, you know all the opinions that we read, but I'm wondering about real world experiences;
Does upgrading the capacitors especially in the output section of our decks make an audible difference versus the stock capacitors that it came with?
Not just yes or no, why does it?
Edit;
I should've originally stated this, and one of the variables is… What if the original caps are within spec, or the original (ones out of spec) caps replaced with OEM grade caps. So basically stock caps versus what the audio world calls high end caps.
Thanks again I appreciate the warm welcome.
Edit;
