Custom Face Plate for Clair Chassis with handles
I had this custom face plate made and it will fit a Clair Chassis. Does your Clair need a face lift??? I had it sandblasted, powder coated, and laser etched, and it has new handles. Looks great. $125 with shipping. I know some of the Clair's had some beat up faces..... It's been on my shelf and I forgot about it.... Spring cleaning don'tya know...... IMG_5597rs (2208 x 1656).jpg IMG_5598rs (2208 x 1656).jpg IMG_5599rs (2208 x 1656).jpg IMG_5600rs (2208 x 1656).jpg
What are you putting it on? Remember, the Clair Face plates were drilled different than the Series II's. The handle spacing is the same as a 700B but you CAN drill a series II so you could use it. Pretty easy. Done a few. The faces of the Clair and series II's are the same just the handle holes (which is where the face mounts to the Chassis). Joe's chassis come drilled for both.
