- Apr 17, 2014
So I've just repaired the amplifier part of this RA-6500 integrated amp, and now I'm moving on to the tape deck. The transport is fine, but I've got something electrical amiss. I get a loud chirping from both channels -- although sometimes the right channel seems like an echo of the left channel - it's a lower volume and feels like a bleed over from the left channel. But sometimes it's full volume too. This happens when pressing play without a tape loaded in the mechanism. When a tape is loaded I can hear music but the chirping is still there and much louder. If I press stop, I can still faintly hear the chirping.
Unplugging the heads from the main board stops the chirping cold. Does this mean my heads are bad? Or could I have some other issue at hand here? I'd think if it was downstream of the heads the problem would persist without the heads attached. Thoughts?
Here's a video of the problem: https://www.youtube.com/watch?v=7Ltn0meAWhU
Here's the service manual:
View attachment panasonic_ra-6500.pdf
The deck records fine, but playback does this every time. I suppose it could be the playback preamp transistors gone bad, but it seems unlikely it would do this with both channels and it would seem to me that it should chirp when the heads are unplugged if it was those transistors. Thoughts?
Charles.
Charles.
