Just cracked open Elmers Carver M1.0t to do an upgrade. I'll post some pics here shortly. Had to get the funk scrubbed out and get off the old corrosive glue which holds down the power supply caps. Should be fun. I completed his C-1 Pre this morning. The RCA upgrade from the standard PL/Carver plastic stuff is very time consuming. There are about 50 jumpers to do but it looks really nice and the gold RCA's should perform as good or BETTER. I think I'll do a 4000t with this same RCA upgrade. I've had a few of the preamps show up with the metal RCA fitting pulled off of the plastic portion. I have spares but some RCA cables fit so tight, it plucks them out.... Not so with the RCA upgrade. I have my 4000t I think I'll experiment with soon. The adapter for the C-1 is the same as the 4000t layout but the 4000t layout is just a little shorter so I need to cut the adapter shorter to fit.
