Kevin,
If you're still having problems with your recorded discs playing in the car here is a site that may provide a solution:
http://www.americal.com/pg/cd-r-faq.html#9" onclick="window.open(this.href);return false;
I copied and pasted #9 below. This information and much more is available on the website referenced above. I now use CD's that I can print labels directly to the CD as I've had problems with paper labels in the past.
(9) What about making CD-Rs for cars and portables?
Here's the scoop on how to create CD-R discs that will have a "fighting chance" to playback flawlessly in your portable and automobile CD players, as well as your home CD stereo system and computer drives...
First, you need to realize that store-bought music CD-ROMs and your home recorded CD-Rs are NOT the same kind of disc, even though they look very much alike, and are playable in the same players.
HERE IS WHY:
Unlike store-bought music CD-ROM discs, your recordable CD-R discs have a special layer that contains a chemical that responds to the heat generated by a CD burner's laser. That's a very short (microsecond long) recording laser blast. It passes up through the bottom, then bounces down off the top silver reflector again almost instantly -- making the plastic even hotter in that area. This heats up the plastic around the laser beam, and creates a tiny bubble. When the disc is played back, the CD player shines a lower powered laser beam up into the discs and scans it. The player's logic chip decodes these little bubbles into beautiful music. This special bottom dye layer's material must be very sensitive to the laser heat in order to produce well defined bubbles for each and every tiny burst the laser makes.
By contrast, the CD-ROM discs you buy in music stores are MECHANICALLY stamped like old-fashioned vinyl LPs used to be. They do NOT contain the heat-sensitive layer like recordable CD-R discs do. Furthermore, since they do not need to be responsive to a heat-generating laser burst like CD-R discs, they use an inexpensive aluminum reflector on top, instead of the much more expensive silver or gold used by recordable CD-R discs.
When you leave your CD-R discs in a hot auto interior or portable CD player in the sun, the heat sensitive layer in the recordable disc responds to the heat microscopically, softening the edges of the bubbles that encode your music data. This process may continue over time, until the disc becomes no longer playable.
If you store CD-R discs in the sun, this process is unfortunately unavoidable. Any disc sensitive enough to a recording burners's laser to get properly "burned" or recorded will also be sensitive enough to an automobile's sun-heated interior to get ruined.
Due to the even MORE sensitive dyes used in high speed CD-Rs (those rated 24X and above), this problem can be even worse. And, most CD-Rs you buy these days are 24X or faster rated, meaning that they are more sensitive than ever to sitting in a sunlight automobile's "oven".
So, CD-ROM discs and CD-R discs are made differently. All CD-R discs will be at least somewhat sensitive to heat and strong UV light, especially if stored for long periods. The least sensitive disc we sell for heat exposure would be the "silver/lt-green" type discs, which use a special phthalocyanine recording layer dye, made to minimize environmental stability problems. However, no type of CD-R can withstand long exposures to extremely hot conditions such as the super-heated interiors of automobiles sitting in the sun.
RECOMMENDATIONS:
* Order CD-R discs featuring the "Improved" light green dye on the bottom recording side. This is the phthalocyanine dye considered most stable and least sensitive to environmental heat and UV light exposure factors. See our Improved Silver CDRs at... click here
* Order the SLOWEST WRITE SPEED RATED CD-R discs that will meet your minimum requirements from the available offerings. Those discs have a tendency to be less heat sensitive. Remember that all discs will PLAY at any speed once they are properly recorded. Our 16X, 24X and 32X are preferred to minimize possible problems with heat and UV light.
* Be sure to use our "no-wobble" CD/DVD labels and apply them with the new Avery Label Tool to make sure they are bubble free and centered properly. This will minimize the possibility of playback errors when the discs are spun at high speeds to today's fast new CD players. See the "no-wobble" labels at... click here
* See Avery's "full face" type CD label applicator took kit at... click here
* Don't store CD-R discs in a closed up auto interior exposed to the sun, when possible.
* Also, when you have to leave them in the car at all, try to protect them inside a well padded and insulated CD case with a zipper closure, and NOT inside the in-dash or trunk-mounted CD player.
* Especially avoid leaving the CD-R discs in direct sunlight, such as on the dashboard or on the seats. Under the seats is better.
* If possible, roll down a window above a half-inch on each side of the car and use a windshield sun-shade to help lower the interior temperature.
That's our best advice for cars and portable CD-R burning... We hope this information helps you create CDs strong enough to have a fighting chance in today's popular in-dash and portable CD players, and that you will enjoy your CD-R discs for years to come!
