- May 14, 2014
- Southwest Kootenays BC
For less than $10, I took home today a NAD 5100 CD player knowing it had a problem. The tray would not open. Took the gamble that there was a disc stuck inside or maybe needed a belt. Turned out to be broken plastic anchors for the disc clamp assembly's pivot pins. I gave the player a shake while upside down and the broken parts dropped out.
Whenever I try gluing plastic, I always seem to pick the wrong adhesive. Most often, there is only one shot at a successful join because residue from a bad one usually precludes a second try.
I don't know what kind of plastic it is nor do I know if it even matters. I was hoping someone here can suggest a strong, permanent plastic glue/cement/adhesive that sets quickly, but not instantly, and requires no pressure or clamping during the process.
I wish to glue this
Onto this
So it will hold this
I wish to glue this
Onto this
