BIIIIGGGGG Advantage on the WOPL Backplanes. There is a bit more to it than just the plugging of transistors.. Just having a robust pair of circuit boards makes working on one a much easier task. Have you looked at an original socket for the transistors? They fall apart when removed. The components on a new backplane are easier to change IF you ever have a part that needs replacement.
