- Nov 3, 2016
- Brooklyn NY
- Are you satisfied with the life you're living
Would you buy this...https://www.aliexpress.com/item/Fin...001c,scm-url:1007.13338.98644.000000000000000
Reference Accuphase E305 amplifier circuit with perfect protection circuit
Field Diamond Tube Diamond Differential Structure with Double Differential Input
Has a very low crossover distortion
E305 is pure DC, the entire line does not have a coupling capacitor, there is no feedback capacitor, is a negative current feedback type, with excellent dynamic response and dive depth
Input part of the key components using Toshiba K170J74
The power output transistor is ON 4281/4302, Three pairs per channel
Full aluminum chassis
