I never heard an 8 track tape ,
so how is the sound of this sytem : low fi , mediium fi or hi fi ?
It' s a my great curiosity .
Furthermore what is the best player/ recorder : Akai ( cr 81 -82) , Pioneer ( r-h 99 -100 ) or else ?
Ciao
Marco
I've been into 8 tracks for about 5 years and went off the deep end with both decks and tapes. The decks I've seen cited most often as being the best sounding are Wolensak, those Akai's and those Pioneer's. I've never seen or heard a Wolensak but am very familiar with Akai CR-81's and somewhat familiar with those Pioneers.
The consensus on Wolensak is good sounding but prone to motor failure.
Those Akai models are heavy duty beyond believe and use the same AC motor used in GX4000 reel to reels. The 82 model has glass GX heads which although attractive spec wise, can be flawed, prone to cracking and are unreplaceable. Other than that, and a Pause button on the 82, it and the 81 are identical.
I only had one Pioneer, an HR-100, but it had a hard life and lost half of it's playback volume after a few months. I relegated it to "mule" duty - using it to run newly acquired tapes through to quickly find the splice. But it's DC motor seized and I've since cannibalized it for the odd part.
I know Nando has at least one Pioneer 8 track deck so maybe he'll be offering more insight.
My recommendation would be a CR-81D and if you lifted one up, you'd know why. I've had 3, still own two and the belts were good in all of them. They remind me of belts used in vacuum cleaners to drive beater rollers.
There are also Akai CR-83D's. Some don't like them because they have DC motors and are not as robust as their predecessors. I've been using one since last fall and once I corrected a few issues, it sounds fine to me. Plus I think it is a very good looking deck with all the features except Dolby which I don't care about anyway.
As long as 8 track cartridges have not been partially erased from bad storage or been physically abused, they sound just as good as anything else. Different from CD and most LP's, better than pre-recorded cassettes and close to reel to reel recordings. You get used to songs fading out, program change noise from deck, then resuming again.
If you do take the plunge, and I cannot stress this enough, do not play any cartridge without overhauling it first. There is a 90% chance of needing new pads and foil splices, 50% the tape pack has layers stuck to itself, and 10% to 20% chance the tape has crawled up the hub. The latter is very bad unless dealt with first. Sometimes for reasons unknown, the tape will have flipped sides and that is a time consuming fix but fortunately not too common. - less than 1% or so.
I currently own over 700 8 track tapes but have reconditioned more like 2500. I like to think I've gotten inside every type of cartridge ever made and witnessed every problem which can occur. Some take a LOOONG TIME to correct.
