Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
Thread: Bridged Phase Linear series ll
  1. #41
    Forum Veteran
    Join Date
    Dec 2012
    Orlando
    Posts
    129
    Quote Originally Posted by laatsch55 View Post
    In theory, it should quadruple the output.
    The "theory" is based a few factors... mainly power supply regulation, and amp design. The theory assumes the power supply voltage will not droop and that the amp has enough current gain to drive the load. Most power supplies will droop and the driver and output stage will have beta droop, so your output power will not reach the theoretical 4 times.
    The 700 is speced at 350 8 Ohm and 500 4 Ohm, so 1100 mono at 8 Ohm is right where it should be.
  2. #42
    laatsch55's Avatar
    Join Date
    Jan 2011
    Posts
    54,225
    Oh, I agree bud. The power supply is the limiting factor...
    taking something that's already good, and making it better...........and for the knowing smiles that cross their faces.......Nando-2011...
    "Silence cannot be Misquoted"--Lazarus Short-2012 "
    " I Just Collect Smiles Craig......Cheap Smiles!-----Fishoz-2017
    "anything can be done, it's finding the easiest way that's hard"-----Bobbysdad--2014
    " Synth percussion is deadly to children, house pets and shitty power supplies"---Stephen Evans 2014
    " You have not reached the point of diminishing returns, you've just ran out of money
    " The Pioneer U-24, unfortunately, is just too expensive and rare to find. That's why I have one."--Nando-2014
  3. #43
    Forum Veteran VSAT88's Avatar
    Join Date
    Sep 2017
    Phenix City Alabama
    Posts
    426
    Like my BlueTooth ?
    Quote Originally Posted by WOPL Sniffer View Post
    Damn Glen, These things dwarf the caps we use in the 700 wopl's...... I'm gonna need a bigger Chassis. I hope to work on my Mono Boards in the next couple days.... Just got a few components to change out. They should really Kick some ass in the 700 configuration. The 2 big torroids, and these big monstrosities, should help keep the rail voltage up and steady. I see a "Brown Out" happening soon.
    Attachment 31378Attachment 31377
    !! HOLY MACKEREL!!
    Main System: PC-Audioquest Jitterbug / Technics SL-3300-Schitt DAC-Sumo Diana-B&K EX 442-Polk SDA2b's
    Confucius say, panties not best thing on earth, but next to it. Confucius say, man who like stereo love to boom boom.
  4. #44
    Forum Veteran WOPL Sniffer's Avatar
    Join Date
    Aug 2015
    Arizona
    Posts
    3,211
    Quote Originally Posted by Skratch View Post
    Are you gonna soft start these?
    Yep, ya have to...... I've had the power supply up and running already....... the soft start boards work great.
    I had the nations problems figured out one night while on blah blah blah........ huh?
    Big amps
    Kenner Close N Play
  5. #45
    Forum Veteran Northwinds's Avatar
    Join Date
    Mar 2013
    Posts
    7,259
    This is an interesting amp, check out those cans. Can you guess the amp manufacturer? The transformer is enormous
    "I really can't begin to describe what happens at that frequency when you hit that SPL, but it's serious. We saw a mouse stagger out of a crack in the concrete floor and die"
    Yweblwrs...
    Quote Originally Posted by skynyrd77
    The only toilet I have seen that didnt swirl was in a trailor
    Quote Originally Posted by TheWOPLwhiffer View Post
    now I need a Dim Bulb Tester to test my Dim Bulb Tester
    Quote Originally Posted by lattiboy, post: 11205733, member: 245918
    my eyes were forced shut by the air pressure change
    An audiophile is someone who's stereo is worth more than his car
  6. #46
    Join Date
    Aug 2015
    Arizona
    Posts
    3,211
    Kenner?
    Big amps
    Kenner Close N Play
  7. #47
    Forum Veteran 62vauxhall's Avatar
    Join Date
    May 2014
    Greater Vancouver Area. BC
    Posts
    1,333
    Output devices are inside that enclosure?
Similar Threads
  1. Looking for Phase Linear 3500 Series II and Phase Linear 5000 Tuner Series II
    By ElectronMan in forum Amps, PreAmps, and Receivers
    Last Post: 12-15-2016, 07:40 PM
  2. Phase Linear 400 Series II on AK
    By Northwinds in forum Forum Buy/Sell/Trade
    Last Post: 08-31-2014, 04:02 PM
  3. Phase Linear 200 Series 2 on loan
    By derek92994 in forum Amps, PreAmps, and Receivers
    Last Post: 11-01-2013, 07:44 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
